Can the CR node of the material editor be exposed? It is too troublesome to select nodes to enter 4 levels now.
Hello @MX.Iee,
Thank you for bringing this to our attention.
I’m not sure I understood your inquiry correctly, so could you please elaborate a little bit more about it?
Does dragging and relating from the channel’s connection work for you? (see attached image)
Looking forward to hearing from you.
Cheers!
Without the extra information requested by support, can’t add this to the Ideas Portal. If the suggestion is still relevant, please add a new suggestion on https://chaoscorona.ideas.aha.io/ and include the answers to the questions above, and the suggestion can then be tracked from there. Thanks!
