Active Shade Rendering continues after Frame Buffer is closed
I just noticed in the Vray message window that Active Shade Rendering continues even after the Frame buffer is closed. This happens only when I use Active Shade from the “Active Shade Floater” button wich is available in customize/customize user interface/toolbars/all commands/active shade floater/. This also happen when I bring up active shade from the script command actionMan.executeAction 0 “40701”. I prefer using the floater as I don’ t have to switch renderer when I have to quickly adjust some lights or materials.
It’ s not a big deal. It stops when hitting the stop button in the frame buffer before closing it. I just stumbled across this because everything was pretty slow after closing the window.
max2014/Vray 3.50.04
Thanks for letting us know. This was reported in our system.
We will update the thread when we have any progress on it.
