Add more Primitives to Vray Core
Is it possible to add a couple of more primitives to Vray? We got a sphere but I would love to have disks and quads. Arnold and 3delight have them.
Hey @hsz ,
the “Render Points As” option under the Geometry node → Geometry tab is supported - the “Circles” option will produce flat disks.
Are we talking about rendering particles, or about the primitives in the SOP level ?
Best regards!
Got it - Yeah I was talking about render primitives. Rendering the shapes at render time, which way faster than a copy to points/instance. So we can add millions of particles without too much of a hit.
Glad that the Vray core supports those primitives shapes at the render time.
Hey @hsz ,
one of the devs just mentioned there are additional types that are supported. We could expose those as Object Properties I suppose, in case you find them useful:
multipoints; multistreak; points; Spheres; Sprites; Streak
Where for multipoints/sprites/streaks there are the following parameters:
radius: float = 1, The constant particle radius when radii is empty., gpuSupport=(full)
sprite_size_x: float = 1, The width of sprite particles in world units., gpuSupport=(none)
sprite_size_y: float = 1, The height of sprite particles in world units., gpuSupport=(none)
sprite_twist: float = 0, The twist of sprite particles in degrees., gpuSupport=(none)
sprite_scale_x: float, unlimited list, Parameter for per particle scale on the X-axis., gpuSupport=(none)
sprite_scale_y: float, unlimited list, Parameter for per particle scale on the Y-axis., gpuSupport=(none)
sprite_rotate: float, unlimited list, Parameter for per particle twist (z-axis rotation)., gpuSupport=(none)
sprite_orientation: integer = 0, 0 - orient sprites towards the camera center, 1 - orient sprites parallel to the camera plane, gpuSupport=(none)
point_size: float = 1, The size of point and multipoint particles, in pixels., gpuSupport=(none)
point_radii: bool = false, If true, the point size will be taken form radii parameter, gpuSupport=(none)
point_world_size: bool = false, If true, the point size is in world space, not screen space, gpuSupport=(none)
point_size_from_ortho_width: bool = false, If true and the camera is orthographic, the size is calculated from the camera’s width, gpuSupport=(none)
multi_count: integer = 1, The number of particles generated for each input particle, when the render type is multipoints or multistreaks., gpuSupport=(none)
multi_radius: float = 0, The maximum distance between the original and a generated particle when the render type is multipoints or multistreaks., gpuSupport=(none)
line_width: float = 1, The width of streak particles, in pixels, gpuSupport=(none)
tail_length: float = 1, The length of streak particles, in world units, the actual length depends on the particle velocity as well., gpuSupport=(none)
If any of those look useful, please ping me and we’ll figure out a way to add those options.
Best regards!
Yes, please add the to obj properties! More options are always welcome! Thanks, Gosho!
