Adding another Vray License
What is the process to add another vray lincense to an exisint account. Do we just buy another copy of vray then email chaos and ask them to add the lincese to our existing lincense server?
I’m not sure that is correct?
thanks,
Z
yep, thats right
cool thanks! 8)
Hi Guys,
Do we really buy another license? isnt we have 10 cpu license when we bought a copy of vray?
/Ryan
I think that 10 cpu is only for DR :slight_smile:
Marco
actually its 10 computer limit. not a limit on the processors. but there is only one work liscence. so basically in an office with two people only one person can use vray at a time. with two liscence a: two people can use vray at the same time and b: if they had 20 computers on their farm they can now use all on a DR. i think chaos should have 2 types of liscence packages. a work liscence extension to add anouther liscence which cost the same amount as getting 1 liscence. and the other type is a DR liscence extension which adds another 10 computer to the DR but doesnt add a work liscence. this package would cost less naturally. what do you think?
Da elf, we have 12 machines in the renderfarm, and 2 Vray licenses. Yet when I do a DR render from my workstation, I can still only get 10 machines involved. I believe the windows 10 connection limit comes into play.
I believe its quite easy to get around that 10 connection limit within XP :wink:
Just requires a few changes files.
do explain. although ive only got 3 computer…opps. 2, one just crapped out half an hour ago on me and if i cant figure out how to fix it tomorow then it will remain 2 i guess
Cool, I will dig up the info tonight when i get home. (3 or so hours)
Whats wrong with your dead PC? hardware? software?
check take-5 ill explain there
found in discreet’s forum:
"It seems that this is a new “feature” of XP SP2: it limits tcp connections to 10 ( type net config server in command prompt).
There’s a hack to patch tcp.sys, and boost your max connections. You can download it on this page:
www.LvlLord.de - Tipps, Tricks & Utilities - Tools but haven’t tried it yet.
There’s also another value you can change, that will probably help: the idle session timeout. By default it’s 15min., but if you lower it (NET CONFIG SERVER /Autodisconnect:mm), perhaps it will close connections more rapidly to allow other connections.
So, who’s gonna try this? "
Yeah i think thats pretty much the info I have at home.. or something awefully similar.
Hi guys,
I just wana make things clear. can i use DR if i buy another vray license? the purpose is that i could use vray simultaneously yet use DR for all rendering animations.
/Ryan
With 1 vray licence you can use DR
Having more than 1 vray licence just allows 2 or more people to setup a scene using vray within max… e.g. lighting and texturing.
Hi Daforce
I got your point there. but what i meant was the other way around. having to license using DR. will that work? my plan is to usable vrays without losing DR.
Ryan
maby this will help,
1 licence of V-Ray gives you:
Single user licence for working on scenes
Distributed Rendering: up to 10 computer limit
Network rendering: unlimited network nodes can be used
2 Licences of V-Ray gives you:
two user licences for working on scenes at the same time on the network
Distributed Rendering: up to 20 computer limit
-dave
thats what i said hehe
but i still think there should be a full liscence and a DR liscence being sold. so that buying a second full liscence would be what you described but buying an extra DR liscence doesnt add the capability of another user but does add another 10 computers to DR (this would be a cheaper addition naturally)
ah k, didnt know that DR licences were avaliable :slight_smile:
-dave
nah, i was just saying that they should do that. its not something they do. it would be cool for people who build a renderfarm and dont really need all the work liscences.
