I have created a Light Cache file and an Irradiance Map for a walkthrough and I have used those file to test the animation at various frames. I have found that I need more detail so if I chose to create additional irradiance maps and add it to the original map that I created, would I use Incremental Add to Current Map and save over the original map?
I think that this is the method but I havent had any luck.
Only way that I’ve been able to combine is to create 2 irradiance maps - Map1 and then later a separate Map2 featuring the additional frames and then use the Irrad Map viewer to merge them.
ANyone help?
