AI 3D Generation: image to 3D model
Status: released
Status history
Very happy to see this feature directly in Vray!
Would like to add multiple image views of an object like front, side and perspective views to make sure the generated model looks correct from all angles?
Also, when I drag in the finished model, the scale is like 1000x smaller - not sure of the scale factor.
I work in metric mm.
Preset settings set to high with Shape Fidelity at the default 7.5
Just my observations - much needed feature indeed!
Edit: Imagine you could link up this asset generator to Chat GPT or Claude.
Then the image can be analyzed first and you could have a bit of a conversation of what is going on in the image.
Then the asset generator knows exactly what it’s generating and will be able to fill in the blanks as it knows now that it is a sofa set from this manufacturer, etc…
Hi, thank you for the feedback! A couple of days ago we released a second model - Tencent HY3D. You can give it a try - it should handle the back of the sofa better and most likely the woman.
As for the scale - it’s a known limitation and we’re working on it :+1:
This was released in Chaos Cosmos. You could update it.
