Alpha Chanel
Hi
I`m having a problem with exporting png with transparent background on c4d using corona renderer, someone can help me figure out how i can do it? i select alpha chanel but everything comes blank
W/o knowing your render specifics/ settings or having a dive into an exemplary file, it’s kinda hard to know…
Have you took a look around? There’s been some similar issues resolved or not…?
hi! so i figure that in my file dont show anything but then when i open on photoshop it come normally. so idk. but thnak u !
This may also be useful for you, within the shader properties you can select the layerset, if your image has an alpha embedded into it it can be manually selected here as well.
