Alpha/Gamma correction
A simple question… Does anyone know if there is a way to automatically save rendered images with correct 2.2 gamma, rather than altering the image in Photoshop?
Thanks!
Josh
Re: Alpha/Gamma correction
… set output 2.2 at the Vray global switches (and input 2.2 and both correction options enable).
It should be on by default, so if you see it enabled you shouldn’t have to worry about it.
