Alpha map visible in Reflections
Hi
I just noticed that the invisible part of my PNG backdrop (the alpha part) is showing up as black in reflections when using High or Ultra Render Quality.
Hi @silverwingsltd
thanks for your report. We are already aware of the issue and have implemented a fix, which will be released soon. See also this existing thread:
RE: mirror not rendering alpha cutout correctly (3.4)
As described there, a possible workaround would be to set the Material Type to Foliage instead.
Hope that helps!
