Anialiasing against background - VraySky
got a little problem with antialiasing.
The Edges of the Window aren’t very smooth after rendering. AlphaChannel works fine.
Changing of imagefilter made no difference.
Environment - Background is a VRaySky.
Any Ideas?
Try using clamp output and sub pixel mapping!
clamp output and sub pixel mapping makes the same result.
The recommended way to deal with this is to enable lens effects to add a bit of bloom/glare to the image, which usually smooths these out. In V-Ray Next update 1, it works pretty well.
Thanks, lens effect works …
