animate different asperct ratio
when we create images with diffeent aspect ratio and we put them with transition in timeline, it would be very nice and cinematic if the format is animated as well,
For instance if you start with a landscape format and then you transition to a portrait one it would be nice to have the black bars left and right to be animated so that the transition from landscape to portrait would be smooth.
THis is a technique that is being used in cinema a lot.
In archviz is very important because very often architectural scenes are much better represented in portrait format
Thanks in advance
Hi!
While this effect would be a nice addition, it has some technical challenges that make it difficult to implement. Wouldn’t it be possible to achieve the same effect in post? What is the reason for requesting it during real-time playback?
Simeon
Hi Simeon
Of course it is possible to do in post production at premiere, as many things, (like color correction) but it takes much longer, and it would be much more intuitive to have this in vantage, will save a lot of time.
Thanks anyways, if y ou ever find a feasible way to get this done in vantage it would be welcome
