Animation changed?
Just fired up Enscape after installing new update, is there a tutorial on how the animation works now? I cannot figure it out any more.
Huh?
Seems like animation setting are missing, how can I change duration of animation? those controls are gone from current preview version.
Heres a blog post on the currently released animation system: https://enscape3d.com/best-practices-video-creation-in-revit-2019/
Please understand that we do not provide documentation for preview versions, partially because the features are still changing.
However the preview thread contains information, see e.g. simons first post or following ones: New Preview Version
I tried to setup a short animation and I don’t get it.
  • I leaved the video editor and I found no way to bring it back. Looks like leaving the videoe editor destroy the current setup. Is it right? Only adding a keyframe per “k” bring back the keyframe editor UI?
  • I added three keyframes and I found no way to add one more at the beginning of the animation.
  • If I added a key frame at the wrong position I would like to move it at the right position at the time line. Also I would like to free arrange all key frames at the time line per drag&drop.
  • I found no way to set the duration or the movement speed. (Seems to be the only way is per adjusting the timestamp of the last keyframe for the duration.)
  • I miss a way to move through the animation per slider to see and adjust the smoothness of the camera motion.
  • I could be great to click on the time line and to add a keyframe per right mouse button.
  • “Save path” and “load path” option at the Video editor would be useful.
Without enabled time stamp function the key frames are automatic set at the timeline. If I like to adjust the position I need to enable the timestamp at each key frame. If I want to change the whole duration later than I need to go through all keyframes again? I would prefer to direct move the keyframe positions at the time line and if the duration of the last one is changed, all other keyframes are automatic rearranged.
Which version are you using?
2.2.3.1330
Same for me. How we can adjust the duration of the video?
@Archoverdose Just open the last keyframe and adjust the timestamp.
@Micha please install our latest preview version and try the behavior again.
@Jonathan_Knoefel I installed the latest preview and most problems are still there:
  • I added several keyframes and I found no way to add one more at the beginning of the animation … new keyframes are placed at the end of the animation only. I try to switch the time stamp to 0, but it was not possible. Only moving it to 00:08 was possible and this caused that anything behind 00:08 was reset.
  • I would like to free arrange all key frames at the time line per drag&drop … not possible yet
  • I found no way to set the duration (Seems to be the only way is per adjusting the timestamp of the last keyframe for the duration.) … No way to scale the whole animation? What is, if the client want to get an animation in 45s instead 30s?)
  • I miss a way to move through the animation per slider to see and adjust the smoothness of the camera motion … slider at the time line still missing
  • I could be great to click on the time line and to add a keyframe per right mouse button. So, the right position could be easy set.
