Animation flicker
Hi
I have an texture on a building, set to “blur 0,6” but from a distance it flicker due to the lines on it.
here is a movie clip http://www.3dbureau.dk/temp/anim/V360-1.mov
near picture of texture http://www.3dbureau.dk/temp/anim/V360-test-16.jpg
setting http://www.3dbureau.dk/temp/anim/setting.jpg
setting http://www.3dbureau.dk/temp/anim/antialias.jpg
Should I just for the animation, turn up the blur to maybe 2,0 or higher?
you did not show the most important setting - anti aliasing. Im guessing you are using adaptive subdivision? You must play around with the min/max aa settings.
You may need to change your antialiasing filter to a bluring type for animations.
Try the following antialiasing filters
--Soften
--Video
--quadratic
--Area
You may also need to increase your antialias settings as well.
Try using ‘Adaptive DMC’ with settings of min-2 & max-4
also Change your DMC noise threshold to [0.001]
Cheers
