Hi!
I’ve recently upgraded my desktop and hence moved all models from Sketchup 2023 to my NAS.
I’ve had some issues with materials but all are fixed and regular renders in V-ray work like a charm.
Once Sketchup 2024 was released, I updated both the programs (Sketchup and V-ray) to the latest versions, for 2024 (see images attached).
Now, I notice that for my latest model, the animated render doesn’t start. The program seems not to start with rendering at all.
I’ve tried rendering an animation with a new model created in 2024 - which works.. so my best guess its the model (as its a version 2023 build model?)
Is there any way that you guys might know if this is a know error for now?
Let me know what details you need to support.
Cheers!
Ruurt
Hi @rt_visser ,
This is certainly not the expected behaviour.
The best way for us to fix it would be to reproduce the issue on our side.
It would be very helpful if you can share the model that you are trying to render.
You can uploading it via our Support form at https://support.chaos.com/hc/en-us/requests/new ?
Simply mention this forum thread and/or my name in the issue description and we’ll have it inspected right away.
Also, can you please describe the exact steps you follow when producing the crash.
As far as I understand you have done an animation setup in SU 2023 and then you’re just opening and trying to render in SU 2024.
Can you tell us what the original V-Ray version was too?
Regards,
Konstantin
Thank you for sharing the project!
We are able to reproduce the described behaviour and and an issue is going to be logged.
I’ll keep you posted on the development.
Thanks Konstantin!
BTW - behavior is similar for CUDA or RTX rendering..
Cheers!
Ruurt
Hello, @rt_visser ,
I would like to let you know that the issue with animation not being able to start with your project is resolved by our developers by optimizing the scene export. The fix will be included in a next update.
Kind regards,
Iva
