Animation render output save image channels
Today I did a quick animation with vray 5 on rhino 7, and configured to save images.
The result I got was not only the final effect result I wanted, but also this 3 extra images:
.effectsResult
.bumpNormals
.Denoiser
I assume that this could be related to the active denoiser options, but, is there a way to choose that just the effect result with alpha integrated is saved?
Where is this option?
Hi @laborda ,
The Denoiser channel could be omitted, yes, if you go to the Settings from the V-Ray Asset Editor, open the Denoiser rollout and select ‘Hide Denoiser Channel’. For further information, you may visit the following page: V-Ray for SketchUp
Moreover, in the same document you may find valuable information on denoising animations specifically (through our standalone denoiser tool).
