Animation3D with Corona !
I would like to understand what could be the method to obtain a 3D animation
Render test Animation settings:
1Frame = 6passes ( 1.50min./Frame )
24fps
Video 7frame/32frame - Render Output 1536x698 ( .avi ) uncompressed
published to .mp4 with velocity 0.13x
Scene - Model tree 3dyk to converted material in Corona… with Cscatter
PT+PT
Post processing - 4,0
There is a different method to do animation?
Raffaele
Test Animation 3D
Video 760x345px 7sec. ( output format .avi uncompressed )
6passes/frame 0:00:40-45 - Total frame —> Time:0 End:175
Time Configuration = FPS:24
Processing Render = 0:02:15
PT+PT
Test processing Video Time:
-07 sec. 0:02:15
Could you explain what precisely you would like to know and post some single frame images? Your youtube animations are heavily compressed so it’s even hard to guess what’s wrong with them.
Settings Render Time
Hello Maru
I wanted to know if it is correct to produce a video rendering without using the individual frames?
I used the standard technique of 3dsmax, exported movie in. avi uncompressed!
There are other methods to export a movie in Corona?
You should always render out to frames, never to avi or mov files. It something goes wrong you have to re-render the whole animation again.
Render to tga’s, exr’s, png 48bits, etc
Bring that into your editing app or compositor and compress to what ever file format you prefer.
cheers
Hi Javadevil
Thank you very much for this information!
greetings
Raffaele
how you get a final image without noise with only 6 pass ???
Hello wildstar
you have a scene to show?
Thank
Raf
It can be done if you use lots of path tracing samples. 6 passes virtually means 6 subdivs per pixel. This should even produce nice antialiased edges in some cases. I usually try to use as little passes as it can be - why should anyone use for example 100 passes?
Hi maru
phrase full of meaning!
