Yes, you can’t do this at the moment with vray the way the xsi shader does it. You can only try to create a model that has the uv the way you need it. But looking at you reference picture this would be very hard.
You should post to the wishlist.
The vrayshader is almost there. The only thing it does not do right now is to sample a bitmap at the uv coords to get a vector instead it takes the uv as the vector. I bet this could be implemented easily.
uh, I don’t have time right now. The “correct” way to do what you’re asking would be to take the top faces off my chamfered cylinders, create a more extensive array, and conform them to the shape of the dash (console). Or, the quick way would be to array a bunch more of the cylinders, render, and use as an image map on the console.
yeah, the trick is the geometry. I’ve always found chamfered cylinders with a minimal chamfer work well. The material is just a basic vray stainless (black diffuse, white reflect w/fresnel unlocked at 8 IOR and 0.6 glossiness w/24 subdivs. Anisotropy at -0.6 and a radially blurred noise map for the “brushed” look. I forgot to make it Ward though…).
The Vray stainless shader works great. I think the whole issue is Max doesn’t have a radial UV map. Good luck with communicating that wish to Autodesk though… I have never received a single reply to any posts on the worthless Autodesk forum.
Add me to the wish list, This kind of effect are something I have been trying to figure out an easy way to do for ages..
I have not come up with anything though..
I guess Vlado will give us some update when he is back from wherever..
