So I’ve been using ACEScg workflow for a while, and generally it does at least appear to lead to better looking results.
But I still comp in After Effects and am now completely tired of that program’s hopelessly clunky color management system and all those workflow bugs that we all know and love so well, such as footage interpretation changing every time you import something, display issues etc.
One thing I’ve never been clear about is whether there’s any difference in the end result between outputting raw ACES from Vray and then converting back to something like sRGB in comp, versus saving an ACES to sRGB conversion at render time from Vray directly.
Does one workflow afford any advantage over the other?
It depends on the colour transform and gamut-mapping process V-Ray uses to take ACEScg to sRGB, compared with the transform being used in After Effects. Those can potentially produce quite different results.
The moment you convert the scene-linear ACEScg render to a display-referred sRGB image, you’re discarding a significant amount of the original dynamic range and wide-gamut information, which I think kind of defeats the point of working that way in the first place?
In my mind, the goal is therefore to stay scene-linear and in the wider ACEScg colour space for as long as possible, including throughout compositing and grading, and only apply the final display/output transform when you actually export the finished image.
Yes, I think this has always been my understanding. Thanks for explaining/confirming it so clearly… I guess ultimately it boils down to whether it’s worth the endless headache of working in ACES, especially in combination with using After Effects for comping.
