Hi All ?
Is there Solution for Archive Saving in V3?
My mean is a take Archive from All Scene (HDRI, Normal, Roughness, etc Maps,IES ) in one click. like as Thea Render, Lumion? ![]()
:sketchup: <3
Hi All ?
:sketchup: <3
Thanks @Yuri.Ismalova , just to make sure I get it correctly, you would wish to re-save/package everything you added to your scene Enscape related like the Materials and so on? I have forwarded that as a feature request for you - please correct me if I understood anything wrong. ![]()
thanks, Demian , yes you get it correctly. for example, I worked on a scene with some Hdri, normal Map, and roughness map and adding some Skp proxy (not Enscape online library) now I wanna send it to my friend to render it. how can I archive all of this in one file and send it to my friend for rendering?
An archive works differently from a backup. A backup protects ongoing production by keeping a copy of all files. Where a backup overwrites itself after a specified retention time is reached, an archive is usually forever growing.
At the moment, when you want to forward a project with everything included, you will have to make sure that the proxy files, hdri files and so are located in the same directory on that other machine where you stored them initially, to where Enscape links ultimately. You could, for example, create a folder on C:\ called āEnscape Filesā and include subfolders to proxies, textures and so on. Then, when you share the project, you can forward just that folder as well.
Currently, there is no way to, for example, have Enscape package everything together automatically, but that is a feature request on our agenda to which Iāll forward your upvote.
