Its really worth the money. You can translate to your boss the time wasted on bb and other similar things into $ saved, Im sure he would see it differently then. Its the same argument I have every time some one posts about problems with bb.
Deadline is very nice alright. For film jobs it’s handy since it’s got a new feature called draft to auto generate a quicktime of your render once it’s finished, or if you’re rendering to vrimg (which you still have to since exr output isn’t totally perfect) you can automatically convert the rendered frame to an exr via vrimg2exr. You can get it to shut down the render node and wake on lan as it needs to render (to save power) and as often happens with command line renderers they’re very leaky on memory so you can find your nodes paging to disk a lot. Deadline can restart every “n” frames to solve this.
It’s a thing called draft that they’ve got as a feature in their beta which can add a slate to the quicktime, make a film strip of a certain number of frames and so on.
