Hello all,
I would like to share with you some interior images from a residencial complex in Bern, Switzerland.
All done in Cinema 4d and Corona renderer.
Next time try to add thickness to the walls, this would prevent light leakage through corners and edges.
P.S. are clients happy to accept images with oil stains all over the place? Seems kinda over the top for me.
Thanks Romullus!
The walls have thickness, but i think there were spots were bevel may have create that strange/ weird look of leaking light that i could not solved.
I didnt see that oil stains all over the place and aparently the clients also dont.
Maybe some exagerated roughness here in there on wall, will check that next time.
But for the record, the last image from the oven it was not delivered, i just add it here. I assume they would not like it ![]()
I really liked the lighting.
Can you tell us what lighting you used in the scenes?
Thanks and regards!
Thank you Buzzz!
The light used was an a corona sky with an Hdri map and i also have the corona sun activated with a very low intensity ( 0.1 ).
Maybe it is not the most correct/ accuracy way to do, but i guess it helped to get the mood i was looking for.
Best Regards!
