Devs -
Is this happening again? I’ve been working on this project for the past few days and haven’t had any issues. See attached - trees have been updated with a different scale.
So - its looking like the Pine tress assets have changed scale throwing off what i had in my model.
The one on the left was imported just now and the other two were pulled from the tree line. The new import is about 30% large yet in Enscape VP is the same size. Please explain - Was the library updated over the weekend?
I’m trying not to have to rework this tree line. Please let me know if the assets have been changed and or if so being corrected.
Same issue here, reported on Friday: Wrong asset scale issue is back
(but with other assets)
Based on my troubleshooting, pretty sure the issue is not on our side.
Thanks for reporting this, do you have a list of affected assets beyond what Pieter posted in the other thread:
stone 5
stone 3
grass bush
Is the pine tree “Pine 4”?
Yes this Pine Tree 4
Possible Pine tree 1 - 5
My users reported seeing many of the rocks scaled wrongly. Would recommend the artists to check all of them.
These issues have been fairly disruptive so it would be nice if future updates doublecheck against issues like these.
Thank you all for reporting these issues to us!
We’ve analyzed all Assets and fixed all that showed noticeable changes in scale.
We might have missed some Assets with more subtle scaling changes, but the vast majority should be as expected again.
To fix these Assets in your system?
Please close Enscape and Delete the folder: C:\Users%username%\AppData\Local\Temp\Enscape\Assets\
Once this folder is deleted, Restart Enscape and the assets will be showing at the correct scale again.
If you have Assets that are scaled incorrectly in your CAD (this would be the case only for Asset placed after last Friday, the 19th) you also need to replace those Assets.
Please allow us to apologize for any inconvenience this has caused, and please let us know if this does not resolve the issue!
Thank you all for your patience,
Is there a clear understanding of how/why this happened, and can you assure us that it not be an issue in the future?
If 100s/1000s of customers are relying on your assets, it is a bit troubling that at any given time the whole thing could just blow up. While some of the images that came out of this were entertaining, I know some of our users were trying to produce renderings on a deadline and were not amused…
I’ll test this in the morning - thanks for the update
We’ve conducted a thorough analysis of what exactly caused the incorrect scaling of Assets immediately after the release of Enscape 3.0. We’re making sure that safety measures are in place before any new Assets are released, to ensure nothing like this can happen in the future.
Regarding the incorrect scalings you’ve experienced in the past few days, we’re currently working on identifiying the exact cause. We had to reupload many of our Assets and did a visual checkup of all of them beforehand. Unfortunately it seems like some Assets slipped through this checkup. Please be aware that the above mentioned safety measures were not yet in place, as they will take some time to implement.
This incident is taken very seriously here at Enscape up to the highest levels and we’re aware that many of you rely on Enscape to create renderings on tight deadlines.
Thanks Arne for the detailed report, glad to hear this!
The assets that scaled wrongly this week (that we came across) were all assets without a clear scale (like rocks), so perhaps those slipped through the cracks with a visual checkup.
Thank you! this fixed the issue.
CHEERS!
Thank you for letting us know this fixed the issue @jtubb !
Oh no
- The scale on the vegetation has changed by itself. I haven’t touch the scaling of the originals. Still Enscape has changed it and everything has become small. Its regarding Bushes.. Can you help me fix this ?
I’m sorry to hear about that!
Could you then kindly try the guide provided by my colleague above:
If you have Assets that are scaled incorrectly in your CAD (this would be the case only for Assets placed after last Friday, the 19th) you also need to replace those Assets.
And please let me know if that doesn’t do the trick.
