Well, here’s another car rendering.
My first one, so don’t go hard…
Please comment.
__________________
www.morfologic.net
Please comment.
__________________
www.morfologic.net
nice renders, but what with back Headlight. it doesn’t seems real.
nice car paint, did you use anything in the scene for reflections?
did you model the car?
yeah, the rear brakelights let it down.
nik
Hi Kappa2
good work for the first work. ![]()
well to improve it. Did you use any fresnel reflection. i am not sure. i fell the reflections are a bit to strong on the sides faced to you.
also hdri´s together with falloff reflections could improve it a bit. overal i find the light contrasts of balck an white a bit to strong.
and at last (i´ve got a designer here beside me, and his only love are curves so far… no not only of nice whomen, but of G2 and G3 curves). maybe use another meshsmooth on it, and turn on smoothing groups , to leave the overal structure at its place. als you could turn on material groups.
i think you still can see polygon edges in the reflections.
but nice work at last.
Go on.
Tom
Thks for the reply.
No, i didn’t model the car. It’s a Dosh 3D car. But i whish i did…
About those backlights - i’m still strugling… any sugestions??
tom schuelke: i’m actualy an architect, so i’m not that found of curves … (besides some of those nice women
) - I’m more accustomed to walls and stuff, so i guest i dont have that sharp eye for it as your designer friend…
Meshsmooth is on but i guess that was’nt enought… i’ll try materials groups.
No, didn’t had fresnel on…
Still learning from you guys… ![]()
You didn’t model? Then why you’re showing it here?
because maybe he wants to learn how to create materials and lighting? If your trying to learn then who really cares what you model and dont. He probably should have stated he didn’t model it from the start though.
I think the carpaint material is the matter here.
maaan, i’ve been playing with the same model for a while now ![]()
and the same problem with a tale lights! your paint looks great!
This forum is not about modeling. That was quite rude
use egz mats for carpaint
very similar to what I have been working with (This is not a final version as some of my mats are using Brazil shaders, this file was originally rendered in Brazil, and there are plenty of errors on it)
Anyway I used a photo of the rear light and UVW mapped it on. Works ok but it needs soem work. (I think I will duplicate it and use the push modifier (and throw a glass mat on it)
hope that helps (PS I used egz mat for the car paint)
TOm
that taillight u got is finally from a google image search? ![]()
nope, took it myself, same with the number plate.
Tom
