authorization on separate machine
Hi -
When I purchased V-Ray Advanced a week ago, it was during a deadline that dictated the machine that I installed and authorized on. I now would like to re-authorize on a different machine (EDIT: with a different Viz license). Is this possible, and how do I go about doing it?
Thanks -
email Tedi…and it’ll be sorted :smile:
Are both computers on the same network? If so, V-Ray’s new licencing system should enable you to use V-Ray on either puter as long as you have the licencing system running on the original and work on only one at a time.
-dave
Thanks - still working on a project that I don’t want to interrupt, so I’ll stick with my current version for now, but will definitely switch over to the floating license after this work is done.
