Autodesk 3ds Max 2012 Service Pack 2
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17826382&linkID=9241178
Autodesk 3ds Max Design 2012 Service Pack 2
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17826442&linkID=10381720
is anyone running this yet?
any issues?
It looks like BB is not a problem for them…I installed 2012 in two computer to test BB2012 and still I can not make them work.
Somebody here has a way to fix the issue with IPv6?.
Thanks,
Fernando
I installed it and everything is working. There wasn’t anything major on the list of fixes, at least nothing that really effects me. I don’t use Back Burner, and to be honest, I don’t understand why you would. When you use V-Ray DR render, why would you use BB?
u set up 5 scenes, u send them bb with dr settings and all get render in dr mode u go nn :slight_smile:
I see… I have a hard enough time working on one job :slight_smile:
you need to use the 2008.1 version of BB
Bobby, if you try BB you ll see why ppl use it…if you work on a job and need to render separate scenes and render overnight, you simply send the jobs to BB and forget about them..they get rendered overnight so you dont have to get up and switch scenes and start the renders :slight_smile:
What error do u have? There are few ways of fixing BB - one of them is to delete 1 file inside BB folder that could cause slave not to see server and so on - I had it once ;s
which file is that DADAL??
can you point me to the link to the ways for fixing BB?
