Is it possible to make a certain button that would save all the render channels from a VRay frame buffer? It’s something that repeats all the time and it’s sooooo annoying to always go through all the channels everytime and save them manually…
Is there such a possibility already in Vray or at least exposed to Maxscript so I could make a maxscript myself?
Thanks!
EDIT: Save separate render channels in VRay Frame Buffer rollout is not good as it needs to be set before the render…
The only problem with that K is that if you haven’t chosen to write out the file before, you’ve got no option to save the render elements after. If you use the save function, if only saves the render element you’re currently viewing and not the lot of them in one go!
I second that 2!
What you could do is render a little region and thick “save render elements” But this won’t work if you load an image from history and if you change something in the elements.
Set it up quiet a long time back but its all explained in the thread. There is a registry fix so that if you double click on a .vrimg file it auto opens vrayimgtoexr and will auto extract all the elements
