I want to use some PBR metal roughness textures I created in Substance Painter. Blender has a plugin called Node Wrangler for this. With node wrangler you can just select the diffuse texture and it will load all other textures and put them in the correct slot. Is there something like the node wrangler in Blender for 3ds Max and Vray?
