Autumn Beech Forest
Hi, this a promo scene rendered in 3dsmax + Corona 6 for my new photoscaned forestfloors. textures are available at www.textures.com
I used my old Beech trees, but with new photoscaned leaf atlas made for this project.
Trees I used: https://www.turbosquid.com/3d-models/beech-tree-static-3d-model-1150084 and also
https://www.turbosquid.com/3d-models/beech-tree-fagus-sylvatica-3d-max/1122552
Very nicely done! The leaves on the ground look awesome.
https://www.youtube.com/watch?v=A8Y0ONyAlTc … Absolutely amazing. Can you give a bit more insight of how you did the leaves? Thanks
Hi Flavius, do you mean leaves on the floor ? they are scanned leaves using technique called photogrammetry. Then I made this photoscanned data into a ready to use tileable material.
Leaves on the trees are also scanned but using multi-angle method in substance designer to extract normal map data.
I was not ready for this… my speakers were at high, I think my neighbors heard it :slight_smile:
