Background environment map not refracting?
Hello guys,
How do you get to have the environment map to refract inside a refractive object, I’ve tried everything from placing the map in the vray environment refraction/reflection override to the environment of the material but as in the example below with the sphere having a refractive material, it comes out entirely transparent, the environment map is a simple screen (not spherical).
Am i missing a step?
Many thanks in advance for your help.
I think that’s the default behaviour. You could create a projection plane and align and link it to your camera, then place it behind your objects and camera map the image on. That should refract correctly.
Thanks, but I was hoping you wouldn’t say that :), well then if there’s no other way then this must be the solution for now.
Thanks again for the quick reply.
Ignore this post I’m an idiot.
*edit* I thought it would work if you use a Domelight, but after a quick test it seems that the vray dome light comepletly ignores the screen mode option using just a bitmap or the bitmap within an vRayHDRI Map
