background image
Background image doesn’t appear in rendering.
I choose Environment - Background - M and select Bitmpap, I select a jpg file to display, but it doesn’t appear in rendering. It works only if I use it as environment.
Maybe there is some parameters to change that I don’t know.
Someone can help me?
Re: background image
Background image isn’t supported. You can set spherical 360° environment texture or create a surface with a textured emitter in the background.
Or you render your object without background and combine it in photoshop. If you save a rendering in png format and open it photoshop, the empty background is transparent.
thank you, it is very clear.
could you explain please, in the future release , will be supported “rendered background image” ?
