Backplate (Background image) not affected by tonemapping
Status: declined
I wish to make photomatching a little bit smoother when using background images in VFB. When i use a backplate inside the overrides, it get´s changed due to tonemapping but it would be great if we could use a backplate option and not be affected by tonemapping, like Vray does.
That way, i can color match all the elements better since tonemapping on backplates always make the image flat and colors are changed.
Submitted on AHA Ideas (CMAX-I-304).
Doesn’t CoronaTonemapControl map help you achieve this?
Submitted on AHA Ideas by Aram Avetisyan.
Great, didn´t know that existed.
Altough it solved my issue, vray vfb options on that is more straight forward. Anything that could be improved?
Submitted on AHA Ideas.
That would technically be a different requests and I believe there are similar/related ones.
Let’s close this one.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
