Baked
I have a client wanting a fully baked model, both textures, and lighting. Big deal? How do I go about this?
yeah its a big deal. You can’t bake reflections/refractions/specular, so it will be either no reflections or dead reflections. Baking requires good uv’s so chances are you will have to nicely uv everything. Even then, unless your uvs layed out all objects in one square you will have to bake multiple objects and result will be one baked texture per object in one uv space.
Tons of work in other words :slight_smile:
You would thing there would be a one click solution for this?
Flatiron says they can do this, but in my experience it does require a bit more work.
Also depends what they actually want it for? If its for UE4 lets say, then you have to consider how you bake it.
would change the games industry. lot of money been spent trying to do it already.
just say no, it’s not worth your time.
Get more specifics from them. Depending on the model and how many texture sheets they need, just laying out your UVs can take you longer than you would expect. Textures you can probably reuse same texture space for the same textured items like brick, yet your lighting UV space needs to be all unique with no overlap.
It should be billed as a complete add service or new job.
if you’ve never done it before it’s going to take you twice as long as you spent on the images, at least. assuming you dont hit any hiccups that you cant solve straight away.
As Neil says, it’s a PITA. Forget about it.
More details on the model?
I’ve got a pretty straight forward process for baking lighting/textures into geometry. You can get away with a lot via quick and dirty unwrapping. I’ve processed 1-5mil poly scenes with 100+ baked texture maps with relative success. Once it’s looking good, it’s more a matter of how much time you have to do the baking to get clean bakes. But I haven’t used it in any commercial capacity. Only for internal design review - I wish I could show what I’ve got.
side note: wish VrayDenoise could work automatically on these baked textures - without having to jig up some batch process for all the maps afterwards. It’s just too much data to be pushing around (at least for me).
I told the guy that it isn’t something that I am interested in. He said that everyone he has reached out to said the same thing.
Funny, that…
what model is this? interior? like if you have just geometry its doable with work. But if you have things like trees or grass, there is absolutely no way :slight_smile:
I tried to go the route of baking maps on a simple oil rig for a simulator I was making to be used in unity3d and quickly abandoned the idea as it was a HUGE undertaking and not worth it in the end.
its not a hard process, unwrella does a pretty good job of automatically laying out the uvs, you will stil need to tweak them a little but stil it does a good job and flatiron will do a nice bake of the lights, its something i did few years ago on a simple interior and its not as hard as you might think
