Hi all.
I’m just curious about something.
The help documents does say what Force Clamping is, Chaos Docs
But I still don’t get what it is. What is it clamping and why?
Steve ~
Hi all.
Steve ~
It is not always visible to the human eye. it has to do with clamping the color values.
Normally you work in 8-bit color per channel (rgba eg.)
The framebuffer shows / works in much more, 16 or 32-bits (floating point) of color per channel.
when you clamp this, you are only saving the values in the space of 0-255 per channel.
when working in higher bpc you are seeing real values in the spectum 0-1 instead. But with a lot of decimals.
it is my understanding you clamp this in the vfb, so you will not get a highlight with an extremely high value, which can cause trouble in post production.
if you are saving the render in a 8 bpc format, it will be clamped anyway. so by forcing it you get a clamped color space even though the format could hold more data.
just realised this doesnt fully answer your question, but it is what i can contribute with
Thanks a lot for that explanation:)
