Batch edit specific shader value
Hello there!
I have here like 100 vray materials and would like to change just one value (refl sample rate) on each material to the same number. example: 100 books with the same cover material but different diffuse, same refl quality though. setting this manually on each material in the editor is pretty tedious. is there something like a “vray light lister”, where I can sort of “skipping through the lines” and edit the values?
Or do some know how to edit this via script? e.g. “change this value on selected materials of same kind”?
Thank you very much for any hints.
Cheers!
wow. my hero @ the moment!
thank you very much!
