Batch flip Normals in Corona Scene Converter
It would have been nice if Corona Scene converter had a button for Making the Normal -y +y on all selected objects with one click, the same way it has a button for gamme fix.
Maybe the script I am attaching below would work fine for you.
PS: The script will not work if the normal map is not plugged to Corona physical or legacy material and that material is not applied to any object in the scene.
Corona Normal Map Property Adjuster.ms (2.03 KB)
Hi thank you! yeah that works for me :smiley:
