batch render 2.8 preview not working
Still not working with the scene view when batch rendering
Could you please elaborate what the issue is? Is the framing wrong? Is the result different between batch render and immediate render? Is a visual preset linked to the scene?
there is a setting saved in the project itself,
As you can see from the two pictures, the scenes, rendered singularly and within the batch function, is not the same
it does this for every scene taken into the batch rendering
the scenes are saved either from a sketchup animation or enscape view, doesnt matter,
2.7 also did this @Sean_Farrell
is there a solution? I have the same issu.
