I was wondering if there was a script available or anyone knows anything that can help me? I have a model i want to render different camera angles of the same scene and it saves the irmap incase i have to go and re render the image. Does anyone know how how i can tell viz to render for example:
camera 1, render image, save image and irmap
change to camera 2, render image, save image and irmap
Yes there is. Go to scriptspot.com and download the camanager script.
with this script you can set up a number of cameras and choose wich ones you want to have render(it will save the images sequentialy like an animation). as far as saving the irr map, I normally just have it recalc this for each camera, you could try the incrimental add to irr map under the irr map roll out. this may save you time, but the irr map is view dependent so if you render different views it will have to calc the irr map.
