Hi, it’s probably a long shot but is there any chance we could have a dedicated v-ray batch rendering solution like the max default but with included options like exporting render elements, VFB color corrections and other sweet v-ray stuff, since none of this works with the default batch rendering?
Using backburner is not really an option, because it is not a render manager in the way the batch render is, it’s not reusable after making changes.
Would be great to have a better batch render solution, at the moment I use this script http://www.scriptspot.com/3ds-max/scripts/batch-camera-render-2
as it allows you to name files automatically and submit all to backburner in one click etc. and works with Vray elements.
Thanks, I already use those scripts but it seems the render elements are not working with v-ray 3, they aren’t saved. Sergo said he would update the script, but still nothing…
Also, it doesn’t save the VFB color corrections which would be a great feature…
The problem is that V2 doesn’t work with max 2015 At least it didn’t work for me. Which version are you on? I tried it with both 14 and 15, but maybe I’m doing something wrong…
That’s strange because it didn’t work with 2014 for me as well… I should try it again with 2015 when I get some time, maybe I did something wrong…
EDIT: Turns out V2 does work with 2015, it just needs a few seconds to start and opens a cmd window which it never did in 2012 where I used it before.. Also it doesn’t save render elements, not even when I switch off vray VFB in the script, which is sort of a fix for script v1.9, but the elements save in 2 versions for some reason. One looks like it’s just an alpha and the other is the proper element without antialiasing and in tga format, which is weird because I can’t find any setting where I would change this and I never save anything out as tga, so it can’t be picking it up from some other option…
I can’t but second this one 3dsmax’s Batch Render is PITA in daily work if you ask me … not even able to automatically add all the scene cameras !! and that’s one limitation between others … if Chaos could provide a complete batch rendering toolkit, it would be indeed amazing !! or maybe would that be a job for some scripter / coder around
