Looking goood mr Bigguns
Hey thank’s man ![]()
Here’s an update, almost finish the base hair shape, will need to add more hair strands but I think the most boring part is done now ![]()
And here a 2 straight output render with different nose shape (the original one and a new one) , wich one you prefer between the 2 ? I’ll post a front view also later , for now it was render with 2 different lighting so it can be hard to compare.
and 2 more:
And a cropped version of the full render that was W/B . I will put the nostrill darker and more redish in the diffuse, it’s what attrac the attention.. the diffuse is not finished yet in some place.. like this one so it show`s.
ha and some noise small render of one light changing posititon to see how the eyes react.
these are older render,with older make up so don’t look at it too much lol.
Second nose better for me - more delicate taper along the bridge. Again these renders are ridiculous.
hey thank’s man
Here’s an update on the hair model guys, still some tweaks to do but it’s getting there..
That hair workflow got me interested. Whos workflow do you follow or is it ur own?
My own workflow in hairfarm for 3dsmax.
Ah so these are poly extrudes along splines from a cap? I’d say they’re a bit annoying to get right
Can hair farm use soemthing similar to the maya workflow of nurbs patches to guide lines into hair styling?
These are not really polys, but Hairfarms own primitive. They can be cumbersome for some things but in general they really rock (they can also be used for simming for example).
There are also various modifiers to do “HairFromSplines” and alike. Due to most operations beeing modifiers you can really neatly stack them. Makes for a really flexible system. Personally i really like the approach.
Cheers,
Thorsten
looking great…I prefer nose#2
Sure - I’ve seen their extrude type modifier and it seems a bit awkward to me bu then I didn’t realize that it’s a bit like spline vertices in “smooth” interpolation mode. I think I’m a few years off dealing with fur and hair though!ud
Thank’s guy’S!
Hey guy’s I need your feedback now ![]()
Here’s some of the first render with the head ( surprisingy Vray managed to render all of it in one render
but I don’t think I will be able to render it in 5k like I want at the end.. .. but at least for now I can finally have a look at how they are looking now with the face etc) and I would like you to tell me wich variation you like the most between them etc.
Notes: I started to do a glossy map wich is not correct for now.. reflection are too low in some place like chin,neck, and too strong in other like forehead.. so just to say don’t comment on that it will be fixed.. ![]()
The hair shape is not final yet, but starting to look good I think. As for the oranger strands, it’s the first test so I will take them further and make those strand more blond I thin, anyway, you can give me your feedback as I said about the general look I should go for and I’ll see what I do after ![]()
Also she will have a neck lace and other earrings by the way, and cloths.. the clavicule need a bit more work since at first I had in mind it will not be seen.. I’ll fix that. (also, this render is with the new nose, do you prefer it ? )
So there we go: LOOK IT IN BIG PLEASE NOT IN SMALL ![]()
Edit : I can’t wait to get her rigged.. she will look MUCH MORE ALIVE ![]()
my charts:
1 - Dark Blond and dark brown
2 - blond and blue
3 - red with blue
At the end will you print a 3d model in 1:1 scale ??? ![]()
First of all congratulations! Really a professional work.
The one with red hair and dark brown is my preferred, there are others in pure therms of beauty maybe betters (Red hairs with blue eyes, Blonde and blue eyes), but the one I choosed captured me more respect the others.
I like hairs u did, skin, eyes in general the model.. I like your work a lot ![]()
Does she will be one of the Chaos stuff once u will end the model? I’m sure Vlado is waiting
So they discovered all the vray chaosgroup stuff was made by androids… ![]()
dark blond/dark brown, no doubt about it ! ![]()
looking forward to see more…
it is really a pleasure to follow this thread!
I would go with dark blond/dark brown
or if you would tone the red down and make it look for natural (I guess less saturated, a little more to the darker side) I find red with dark brown also nice.
These are the most natural looking to me!
Hey thank’s guys ![]()
Here’s blond ( i have better blond color now ) with purple strands for fun hehe and I changed a bit the lighting, more up this time.
Amazing!
Please make some human size 3D prints and start selling them ![]()
Thank’s man
Hi all
A little update, started to work back again on it this week , took a break had other things to do.
While taking a brake, when I got back on it, I found I had made some changes that were not for the best but was making it worst so I took back an older version of the skin and (in this case also the diffuse, I will update it with the newer diffuse I’m working on in the next update,just small changes and fix like removing the lines that goes from the corner of the nose around the mouth etc). I will also do the nose a bit longer in the front view,etc.
Also, the hairs will get a massive update (on the hairs transition line on the side, since I made the hairs on one side go behind the ears, wich I think look’s better) and I wand to do changes especially at the hairs bottom I have something in mad that will suit her better then now.
I also tweaked the veins in the eyes and made iris more brown and a bit smaller.
I want to do a morpher this weekend for a smile to see how those teeths will look ![]()
Anyay, here’s a sneak peak of what’s going ![]()
feedback welcome
I was about to say “unbelievable” but that would be the complete opposite of what this is… !
Something about the eyebrows is not quite there, for me… too soft maybe? Not sure…
But really, this is amazing work…
This is jaw-dropping amazing! I keep watching each next image posted on this thread and am in awe.
