Bercon Maps for MAX 2027
Hey,
is there any info on when a Bercon maps recompile for MAX 2027 will be available? Tried searching but its not out yet.
Martin
Not yet, this is the github where I have downloded the last versions and still no update yet
Hi Martin,
Bercon Maps for 3Ds Max 2027 Should will be in the Github soon, one of our devs took care of that.
Best,
Muhammed
Its already there, thanks!!!
Great! Enjoy!
Credit to Nikola Yanakiev from the Chaos Team who compiled them for 2027 following the requests.
Best,
Muhammed
I see that screenshot, however is not there, or the link is not working
can you sahre that link? cant find it
Thanks to Nikola Yanakiev :slight_smile:
I’m getting an error message when loading up 3ds Max 2027 that BerconMaps_2027_64.dlt failed to initialize. Error code 193 - is not a valid Win32 application.
I have it working in 3ds Max 2026 on the same workstation.
Has anybody else had this issue or knows how to get it working? Never had this problem before using it over the years.
its working ok on my end
Are you donwloading it from here?
Yeah, that’s the location I downloaded the file from.
I can’t seem to find any similar issues online. It’s a strange one as it’s working on my 2026 Max install.
Try updating your Windows (Start > Check for updates).
Windows is all up to date
ChuckRT is it working for you on Max 2027 service pack 1?
Just wondering if it could be different version updates of Max causing it.
Yep, It worked with Max 27 and 27.1
Dont quite sure if windows is the issue, im using Windows 10 and tested on 11, working ok
Maybe try renaming ENU or uninstall and reinstall Max, dont think that this will do anything but just to check everything
Yeah, that’s not solved it either.
Do you start 3ds Max as admin?
Also, try reinstalling the Microsoft Visual C++ Redistributable through the setup file “vc_redist.x64.exe” included in the V-Ray utils folder (C:\Program Files\Chaos\V-Ray\3ds Max 2027\utils), and restart your PC.
By the way, are you sure you’ve downloaded the .dlt correctly? This is the page you need to download it from. Click on the dots on the right and download.
Thanks! I had the same error loading message. Downloading it from the 3 dots instead of using save-as from the link resolved the error for me. Works as it should now.
