BerconTileTex Tile Mapping problem
I have a problem with tile mapping and the BerconTileTex in Maya. The way the tiling works in Max is by using the UV channel of the color map. Now Maya doesn’t have UV channels, just UV sets. Still in the BerconTileTex node there is only an option to use Tile UV Channel for Tile Mapping which doesn’t work.
Is there any way to make the tiling work in Maya?
Can you post an example? I’m not sure I understand the problem.
Hi Vlado,
I took a screenshot which hopefully clarifies the problem. The image of the jellyfish should be tiled but it is not. In MAX this is done by chooseing the same UV Channel as the Texture node but in Maya there are no UV Channels.
Have you tried to adjust the RepeatUV attribute in the place2dTexture2 node?
I’ve tried it with a checker and it works just fine.
How would someone go about unlocking the bercon maps? I assume theyre hidden since I cant find them in my version of 3.4 here
Create > V-Ray > Create from V-Ray Plugin > Texture
then select anything from the ui
thankyou very much!
would be too cool if this would work in Maya as well. In any other software its standard but not in Maya
The V-Ray plugins for rendering the bercon maps have been there all along.
