Surface = pi x R?
R=1cm (diam 2cm), like a real tape water
Surface = 3.14*1*1 = 3.14cm?.
If 0.2l/s is obtain with a 12.57cm2 surface with a discharge of 1600, then I will need 4 time more discharge for a surface 4 time less.
An emitter of 2cm with a discharge of 6400 = 0.2l/s.
But are you sure about your initial statement of 0.2l/s = 12.57cm2 at 1600 discharge?
I must admit the math side still has me stumped as well.
1600 appears to put out way to much.
In a test on my 1 liter box scene, with a 2cm radius emitter it appears that 1600 puts out 0.4 l per frame.
That’s definitively not the right value, even with 1600 discharge, with a 12.52 cm2 emitter.
Just try to run the 2 first frame with this value and you will right away notice that it is visually wrong. Your face will get as wet as your hand with such type of tape.
The maths was still bugging me so I did some tests. Svetlin correct me if I’m wrong, but this seamed to work.
As far as I can figure the velocity setting is in cm/s (well for my scene anyway as my scene units are cm, I’m guessing it may actually be in scene units per second)
This makes sense to me, as it shouldn’t be tied to grid or else you would need to change it every time you decide to increase/decrease your grid resolution.
So i figured to get 200 cm^3 volume you just divide by your area in cm^2 (3.14) and that gives the velocity in cm (63.69).
Using this method I created the following with 3 different emitters, aiming to fill 1 liter over 5 seconds.
I assume the slight variations in accuracy has to do with grid resolution (mine was set to 0.2 cm)
I believe we’ve already exhausted the topic. If the scene still does not behave the way you expect it to, the best possible approach would be to send it over to Support and we’ll adjust it for you. This would be especially useful when scenes are under NDA.
Thanks Svetlin,
Exhausted is not really the term that fit the best. The topic was simple: How to convert cell per second unit into liter per second unit.
The value, you gently indicated, is not working, so I keep asking…for the benefit of all chaos group users.
On top of all, Phoenix is better than all CFD (your word not mine), i wonder why this information cannot simply be share to all users and benefit to all chaosgroup users.
I’m currently working on a project where Ansys simulation is available. Has there been any development for using the simulation results in Max since then.
