BETA 3 VolumeGrid
I was testing smoke in Vantage and through Live Link everything works fine, but when I load the cache directly into Vantage it stays frozen on the first frame , is that normal?
Hi Pablo,
How are you loading the cache in Vantage? Are loading it through vrscene or using the VolumeGrid object inside Vantage? If you are using the VolumeGrid object in Vantage you have to replace the frame suffix with #### to load the correct cache for the needed frame.
Alexander
Thanks Alexander, did exactly that and it worked
this is not working for me. failed loading
Hi AyrtonSenna,
Can you please share the log(located in %AppData%\Chaos\Vantage\debug_log.txt) or send us the file you are trying to load?
Alexander
