When I use HDRI, the current vantage atmospheric effect is bad. It covers the HDRI image. Hope to support better fog effect when HDR is the background image.
Then, the current fog effect only has color. Can you add the brightness option for it?
Whether to consider increasing the effect of automatic rain and snow? Or can this only be done in 3dsmax?
Try reducing the “Fog max opacity” to a lower value and the HDRI will become visible.
This may be the only solution at present
But it means that the effect of fog will be weakened.
The color of HDRI is rich, but the current fog is a color. This may be the point that makes them unable to match.
When I render with vraycpu, the most common way is to blur the HDRI map and paste it on the color map of fog to obtain the color matching with HDRI. I wonder if this method can be realized?
Or when to support rendering 3dsmaxfog or vrayenvironment fog, so that I can achieve the same effect as vraycpu rendering in vantage
