Better way to check and solve noisy areas in the image
Status: pending
Fstorm has a good and easily accessible way to check for noisy areas and to “force” solving such areas. It’s a green/red/black render element that is easy to use and understand.
Submitted on AHA Ideas (CMAX-I-42).
As a note, when adaptivity is enabled (by default), Corona already detects areas that require more processing and automatically places more processing power there. The results of this can be seen CInfo_SamplingFocus render element, which shows how much processing Corona allocated to an area.
If you have more information on how this is different from your request, that would be most welcome. Thanks!
Submitted on AHA Ideas.
IMO it doesn’t look like adaptivity is doing a great job.
See attached. Corona should be giving more samples to the wall on the back (triangular area near the ceiling). At least that’s what I would do manually.
Some times it doesn’t matter how many passes you leave it running, it just won’t send samples to noisy areas.
Fstorm has the noise levels render element with 3 colors: Black where there’s no noise, red where there’s noise and Fstorm is working on it, and green where there’s some noise but it reached the noise threshold so it stopped working on it.
I believe it’s a better approach than a black and white image that shows you just where the samples are.
A quick search in the forum:
+1. I added the same request a month ago or so, didn’t see this one.
The benefit of having such pass is to get a visual feedback on whether an area is receiving samples or not. It helps “calibrating” the noise threshold to a value that we are pleased with. Corona doesn’t offer this functionality, so only way to see if an area is being rendered or not is to zoom in very far and see if the pixels “move”.
I’m also having a hard time understanding the adaptive rendering in Corona and a pass like this would make it easier to understand.
Fstorm also has another related feature: Dark threshold. Often, we can accept more noise in dark areas because it isn’t actually visible even if it’s there. Corona doesn’t take that into account and keeps rendering dark areas that may not have reache the threshold, but still have no visible noise.
Would be a great way to optimize render times, but again, to be able to calibrate such feature, we would need the noise pass in order to get visual feedback of what corona is rendering and not.
NOTE: V-Ray also has a render pass like this, and Octane as well if I recall correctly. They wouldn’t add it if it wasn’t useful.
Submitted on AHA Ideas by Johannes Lindqvist.
AHA Ideas status: Pending.
Set during AHA Ideas to Discourse migration.
