Hello guys, first want to thank you for this amaizing software, the issue is that when you have a bitmap with no tile arrow assigned it repeats and doesnt take in consideration the back default value that should have 3dsmax an it get rendered, like on leaves on a tree when you have an opacity applied and your bitmap is smaller than your plane so you dont apply the arrow of tiling or mirro, i dont know if its a know issue but it worth to be checked.
This is the solution. I might reconsider the behavior in the future. Now it works consistently with all other channels, but it seems like other renderers treat opacity as a special case.
