I have a problem after installing the latest version of 3ds Max and corona.
A black image appears in the render window. The image is not rendering. After installing the new version of 3ds max 2025 +Corona most models created in earlier versions do not render. After clicking F9 the image goes black and only the “scene parasing” counter changes. Nothing else happens. Sometimes after flipping elements from a model to a new file it renders normally.
I used Scene Converter to Arnold and the redner worked, after converting to Corona the render does not work.
Thank you for your help.
