i have a facade which consist of repeating elements. each element is defined as block, because i want to create several variants and it is easy to redefine one block to change the whole facade.
unfortunately vray rc2 still doesn’t render blocks, although it is mentioned to have been fixed with this release.
when will it finally be supported? i have to explode all blocks before each rendering, quite nasty!
