Hi! Everyone
I try to adjust the bloom function. No reaction at all, to changes at any parameter
Need help
Please!
Meir
Did you try a lower threshold?
Right, since nearly all the intensity is below 1 you don’t get a glow. Try a lower intensity [EDIT: I mean threshold] than 1 and you will see a glow. The problem of your setup is that you don’t have intensive bright areas and it will work better and looks nicer if you have it.
Set the threshold below 1. 1 means pixel value 255 in 8bit. It looks like your image has no large dynamic. Maybe the brightest pixel is around 1 only. All pixel above the threshold will be processed. So, if you set it 0.1 than you should see an effect.
I habe no idea why it doesn’t work. You could try a fresh scene for a test.
Hi StarUpJewelry,
You can also save out the render as a .vrimg file and share it.
We’ll be able to see what is going on on our side.
Thank you in advance,
Konstantin
