Bloom and Glare...
Not sure if this a bug or I am not using it correct… I’m trying to use Bloom and Glare on an image, but I’d like to control the amount in post, so I set the mode of each to ‘Render element only’. The scene renders normally but at the end as it is calculating the Bloom/Glare, I’ve noticed the ‘RGB color’ in the vfb suddenly goes darker. Looks like it is applying some sort of gamma. That darker image is also saved into the output file. Is this the intended behavior?
I’m using 3.30.03
Thanks,
Ryan
Yes, it’s a bug and we are working to fix it.
Here is the discussion: http://forums.chaosgroup.com/showthread.php?85876-Possible-Bug-vray3-3-Lens-Effects-(Bloom)-darkening-RGB-pass&highlight=bloom+element
